7
This discussion topic has been answered Discussion topic: Should i be redirected to myrouter.io?
This message was authored by: Galdukat
Hi,
When i enter 192.168.0.1 into a browser to access my router it seems to flick to https://myrouter.io/
All looks the same but wanted to check this is correct before i enter my username and password
Thanks in advance
This message was authored by: jamesn123 Answer
Re: Should i be redirected to myrouter.io?
@Galdukat
Apparently it is a known change due to how the router is managed in the cloud. Its safe to enter your login details.
I am NOT a Sky Employee
@Galdukat
That is an odd one. Perhaps this is what happens on the newer hub when you try to go to the web interface. @Chrisee have you seen this when using the Max hub?
@Galdukat
Which hub do you have?
Avatar for Galdukat
Hi @jamesn123
I have the Sky Max Hub
I'm sure when i first had it, the address in the web bar just showed http://192.168.0.1/index
If i type that in it changes to https://myrouter.io/
@jamesn123 @Galdukat
A Whois lookup indicates the domain is registered to Comcast, which is probably a clue.
@TimmyBGood
Just asked the question Re cloud management, I suspected it was something to do with that.
@Galdukat
Avatar for Galdukat
Thank you very much for your swift help 😀
This message was authored by: Abglanz
I have the same problem, how did you solve it? 🙂
