Discussion topic: Should I upgrade to wifi Max?
This message was authored by: EpicRay
Hi
Its probably been asked before, should I upgrade from broadband superfast to wifi Max?
I like the thought of being able to set limits on internet time etc - can you have differrent age ratings for different devices? Currently on bb superfast I have the age rating set to 13 which affects everyone in the house rather than the other setting of 18 which would mean the kids being able to search what they wanted
I also pay £6.50 each month for Broadband Boost but the upgrade to wifi Max says "replaces Broadband Boost" - so would that mean i could take Max at £6 per month and cancel boost at £6.50 per month so effectively have better wifi for 50p less than im currently paying?
I see a lot of complaints on here though that the new hub causes lots of isues and isnt very good so that is putting me off as my signal just now everywhere in the house is ok with no real dead spots so I could happily stay as I am but to be honest I like to habe the latest and best hub lol
Re: Should I upgrade to wifi Max?
@EpicRay  If you are looking for that piece of mind about being able to limit your kids then changing what you need to do and if you want the latest tech.
https://www.sky.com/help/articles/sky-wifi-max#
But if you need to check anything give Sky a call to clarify any questions you have.
I'd think that's correct, but remember that Max is only ' better WiFi' (in theory) for WiFi 6 client devices.
