Discussion topic: Samsung TV & Sky Full Fibre
Message posted on 03 Dec 2024 05:50 PM
Hi,
I switched to Sky Full Fibre yesterday and have been unable to connect broadband to my TV - Samsung UE65TU7020
I have factory reset the TV, as well as using the WPS option but it will not connect whatsoever.
Also, my Sky Q box is constantly dropping broadband. Very frustrating as you can imagine!
Any help / advice please?
thanks
Message posted on 03 Dec 2024 06:07 PM
Re: Samsung TV & Sky Full Fibre
@Scotttaylor31 wrote:,
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to temporarily disable the 5Ghz WiFi band: remember to re-enable it afterwards if you do this.
