Discussion topic: Samsung S90D connection to sky q hub
This message was authored by: Only-A-Name
Has anyone successfully connected a Samsung S90D or similar tv via Wi-Fi or lan power line to a sky q ER110 router?
If so how?
Re: Samsung S90D connection to sky q hub
@Only-A-Name
That shouldn't be a problem assuming either wireless range or household power cabling permits it.  What issue are you encountering?
Avatar for Only-A-Name
Tried
1) wired via powerline adapter as used successfully with old TV and hue hub.
2) wifi 5ghz auto detect
3) wps with and without pin
4) fixed ip with all of the above
5)  google and sky dns with above
6) Powered off at plug router and tv then repeated above.
All give from TV connection to network but not Internet.  All other devices on same network can access Internet.
 TV connected to mobile hot-spot can access Internet.
Any ideas ?
If so how?
ected to network but not internet
Both wifi and ethernet show connection to router with IP address showing on connected devices however no connection from tv via router to Internet.
All other devices on network have Internet access.   TV will hoeever connect via s21 mobile hotspot.
This message was authored by: Addie15
