9
Discussion topic: SR203 Changing DNS
This message was authored by Aurynfire This message was authored by: Aurynfire
SR203 Changing DNS
Did sky ever go ahead with allowing us to actually change our DNS servers (while having to turn off IPV6) as reported by ISPReview in 2019?
Fantastically Autistic
This message was authored by TomThumb5ive This message was authored by: TomThumb5ive Answer
Re: SR203 Changing DNS
@Aurynfire  No problem changing your dns servers away from sky's offering but it's still done per client & not a router option!
Tom...
Sky want us to believe in better
BELIEVE =accept that (something) is true, especially without proof.
BETTER = of a higher standard, or more suitable, pleasing, or effective than other things or people:
Sky Q & 2 mini’s
SR203 router. > Replaced with ASUS XT9’s with a TP-Link TD-W9970 modem
Sky superfast 80/20 :sort of, 63-75/15. Devolo 1200 wifi > Replaced with cat 6
Sony KDAF8 65 oled.
Tom...
Sky Q & 2 mini’s
Sony KDAF8 65 oled.
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty
@Aurynfire
Nope, not in the Hub - you'll need to change it on each device or swap out to a different router.
"Sometimes, the only choices you have are bad ones, but you still have to choose"
Aurynfire
Sadly I kinda guessed that would be the case, thanks guys and gals!
This message was authored by marklar666 This message was authored by: marklar666
Or set up an alternative DHCP server on RPi or similar device.
This message was authored by Collyrobbo This message was authored by: Collyrobbo
Hi Tom
what do you mean by client as opposed to router ?
do you mean by device ?
@Collyrobbo wrote:
Hi Tom
@Collyrobbo
Yes, each device as the DNS is locked down on the Sky Hub.
Aurynfire
Wish there was a DECT wireless handset that runs from a sim that I could use so my old man could keep using the phone while I could switch away to a better router.  * I could have the sky calls redirected to the mobile number *
So why does sky lock down  access to the router dns settings ?
Aurynfire
Sky shield for one
