SR102 Access Point & Firestick Issue
Runner
Post 1 of 2
Hi Everyone,
I was wondering if any of you could please help me out. I have set up powerline adapters and an old SR102  to create an access point so I can have better signal in my bedroom. I've followed the various instructions I have found on here, and it works great - for my Xbox, Mac, iPhone devices. However, my Firestick will NOT connect to the SR102 and I'm pulling my hair out over it.
 It sees the access point, connects to it just fine - however will then say 'connected with problems' and not work at all. The home page will not load and I cant use any apps. I just cannot figure out why it works great for the other devices and not at all for the Firestick? I have tried two firesticks and both have the same issue... Any advice would be greatly appreciated.
Thanks for reading.
Oracle
Post 2 of 2
Re: SR102 Access Point & Firestick Issue
Hi @GillespieG
Will need a bit more information to help. Have you tried the fire stick on your main/original router? Does it work? What are the errors on the firestick? If you go into the network config it should give a reason for the network problems.
