2
This discussion topic has been answered Discussion topic: SKy Max fibre, SKY Q.
This message was authored by: paulmerhaba
Recieved router today. Changing router within SKY.  Wifi seems all good. Cannot connect to SKY q box, tried all the procedures on the app to no avail. Ask's me to use WAP, keep pressing it. How long do you have to this for? I after a shortish period of time get green flassing light. This seems to go on forever, nothing happens. when i let go router seems to reset. Hoping someone can help. Thanks in anticipation.
Re: SKy Max fibre, SKY Q.
@paulmerhaba
The WPS button needs pressing briefly on the Hub, and then press the WPS button briefly on the main Q box: this triggers the link setup.
As you've discovered, some design genius decided to make a long press on the Max Hub WPS button act as a router reset.
@paulmerhaba
Avatar for paulmerhaba
Thanks for the reply.
Just tried it again, got  blue light with WAP instead of green. A cough and spluter and it kicked into life. So all connected now. Thank you for your time.
