Discussion topic: Rubbish internet Connection in Poole - BH12
Message posted on 01 Apr 2025 07:39 PM
My speed test apps results are giving 2Mbps - I'm meant to be getting 100!
Sky's test results say my hub is getting the full 100 Mbps - Yeah right!!!
I've rebooted the hub but nothing has changed. Any Suggestions?
Message posted on 02 Apr 2025 08:32 AM
Re: Rubbish internet Connection in Poole - BH12
@OLDJUAN if you are measuring spedds on a device connected by wifi it is likely the issue is poor wifi signal strength in your home. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
