Discussion topic: Rubbish broadband and you don’t care
Message posted on 02 Jun 2025 08:14 PM
Broadband down most of the day again seems very month I pay loads for a rubbish broadband and sky don't care as there still get paid!!!!!!!!!!!!
Message posted on 02 Jun 2025 08:19 PM - last edited: 02 Jun 2025 08:20 PM
Re: Rubbish broadband and you don’t care
For a ‘no broadband’ issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Message posted on 02 Jun 2025 08:23 PM
I've just realised you were given the same advice twice in March so have you subsequently called Sky and have they arranged an engineer or other help?
Message posted on 02 Jun 2025 08:25 PM
It's saying the broadband is good but it's not!!!
Message posted on 02 Jun 2025 08:26 PM
Then please follow the rest of the advice in that first post and if necessary call Sky to report it.
Message posted on 02 Jun 2025 08:28 PM - last edited: 02 Jun 2025 08:29 PM
And that was from the result on the line test via the link posted by @Daniel0210 ?
Are the lights lit on your hub and none of them are flashing ?
What did you do to get it fixed back in March ?
Message posted on 02 Jun 2025 08:33 PM
Have reset and still doesn't work try ring sky but can't get to speak to a human
Message posted on 02 Jun 2025 08:40 PM
@Jester15
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
