Discussion topic: Rubbish WiFi from Sky
Message posted on 12 Jul 2025 09:04 PM - last edited: 12 Jul 2025 09:14 PM
Re: Rubbish WiFi from Sky
@BrandiPad If you feel that you are not capable off anything just say whoa that's out off my comfort zone!
You will also be back connected on a OR Landline phone connection, so is it a Master 5c type socket or are you using the supplied ADSL filter to connect everything to the type off socket that you have.
Also possible depending on what hub you have once you looked at the types, to get data from it and if you have a bad line, the lights on the hub are what do you see when it's playing up to you.
Also it may be nothing to do with the hub, coming down from a VM docsis system to a Landline can be a major shock!
Message posted on 15 Jul 2025 12:20 PM
@JimM1 Ive got the Sky Max hub and I have 500mb/s, but Ive never seen anything near that speed. So are you saying I need the skybox if I want to use the telephone? its included in the package, but I dont use it. TIA
Message posted on 15 Jul 2025 12:35 PM
@LH75 Any chance that you would not mind creating your own post, just way easier to work out what is going on and needed!
Message posted on 15 Jul 2025 10:23 PM
Thank you for your reply, we using a Sky Router, Model SR203, which is connected to the BT Copper Wire phone system using an adapted socket and suitable cable.
None of the ports at the back are populated, just the power connection, and all 4 lights on the front are green. That is how they seem to spend most of their time, even if the service is just not there. They show the router is connected to the Sky Glass receiver box, which often struggles to provide a TV service of the like that I have experienced most of my life.
Fault finding goes as follows:
Switch TV off and on via removal of power cable.
Reboot Sky Reciever via removal of cable.
Reset router via Reset button.
Reset router via power cable removal.
Router resets are carried out after cable connections are proven to be connected correctly between TV & Sky Reciever, and the Router to the telephone socket. Checking of the connection via the provided software is not the most reliable thing I have ever used, and is not something I would expect to have to use on a daily basis. Historically, I tested the status of the WiFi from the router/ hub directly, much more reliable that way.
Not really sure where else to look.
Message posted on 15 Jul 2025 10:37 PM
Just had a further read of your reply and done a bit more looking at VR Docsis - think I need to be doing a bit more research.
When we moved in, the telephone socket was of the original type, but this was changed over by the BT Openreach engineer as part of the set up activity. He also had to make a change or two in the junction box that provides the line to our home.
I'm guessing these are what created the 'digital' broadband facility.
I will report back once I've undertaken a bit more research.
Message posted on 15 Jul 2025 10:44 PM - last edited: 15 Jul 2025 11:06 PM
@BrandiPad Have sent you a PM.
Edit:- With having the 4 Green lights on the SR203 hub this is an indication that the hub is up and connected, so can i have you NOT do the following two items that you have posted from above, they are.
1. Reset router via Reset button.
2. Reset router via power cable removal.
NO need to do the reset button, and removal off the power because you are on the copper fttc line can lead to all kinds off issues with the OR (Openreach) system, it monitors the line but it does not know what is going on, so it thinks BAD, does what is called a DSLAM, start's to reduce the speed to aide stability off the line, WE do not want this to happen, Engineer may have said to you takes 10 day's for the system to work out how it's going to be, does that ring a bell with you!
Message posted on 01 Nov 2025 12:12 AM
I wish I had read these comments before switching back to sky! They promised a much faster internet, but it's as advised only within 2 yards of the router... Coverage within the house is terrible, and even their own tv streaming pucks are not coping - white screens or no sound all the time... I left sky 4 years ago, they actually delivered a better quality then, compared to now. Very disappointing.
Message posted on 01 Nov 2025 01:35 PM
@Rkin1 Call Sky to see whether Extenders or Boosters will help you
Now TV Sports + Entertainment + Cinema + Ultra Boost @ £34 pm (till April 2026)
1000/115 FTTP (Aquiss) to Zyxel DX3301
3 x Asus XT9s + + RT-AC58U V3 for WiFi (AP mode)
65" Samsung S92C OLED TV
C430 Samsung soundbar with subwoofer
6 other streaming TVs
43+ network connected devices
Message posted on 01 Nov 2025 02:54 PM
Left (reluctantly) Plusnet after several happy years with zero problems 500mbps. Not a disconnect, no freezing nothing just worked.
Joined Sky two weeks ago with much trepidation and also due to the much cheaper price (including Netflix @£11). All my fears have came true. Constantly dropping out, frequently disconnecting and despite having Sky max hub and a 'booster' it's been rubbish.
Today I left under my grace period and as I was with Sky broadband about 5 years ago and had the same experience in the last year or so of that contract- engineers, phone calls etc I can safely say I will never be back. Ever.
Message posted on 01 Nov 2025 03:39 PM - last edited: 01 Nov 2025 03:40 PM
Netflix isn't a Sky Broadband thing though: that's part of a Sky Television product.
Message posted on 01 Nov 2025 06:23 PM
To expensive
Message posted on 01 Nov 2025 08:52 PM - last edited: 01 Nov 2025 08:54 PM
Posting two words here (and misspelling one of them) on an unrelated thread won't elicit any response from Sky: this forum is neither an AI-driven environment or a direct point of contact with Sky Support or Sales.
If you want to negotiate pricing, you'll need to call them.
Message posted on 03 Nov 2025 06:38 AM
I know it isn't. Not sure why you thought I was complaining about Netflix from my post
Message posted on 09 Nov 2025 05:10 AM
I'm sticking with talk talk never had a problem I'm 150 fast fiber it's the erro router bin hearing that sky got big problems with Internet
Message posted on 07 Dec 2025 07:17 PM
Your spot on! I'm sitting here watching polar express and an hr in, freezes , using APPLE TV, really **bleep**es me off, I'm going full fibre when it hits us early next year, double to what sky can give. I'm fed up with sky big time. Sick of buffering in 2025 , bet the states don't put up with this **bleep** !! Merry Christmas to all, and to all a good streaming service.
