2
This discussion topic has been answered Discussion topic: Router settings in my sky app - how long to appear?
This message was authored by: Scubaian1
Sky BB installed successfully yesterday with Sky Max Hub - my understanding is if I need to put in port forwarding I need to do it in the My Sky App.  Should the router show straight away or is there a delay and I just need to be more patient?
I am accessing the app, selecting "Product Settings" and I see three options, "Device Management" which shows my sky puck details, "Broadband Shield" for content control and "Internet Security" for some software I'm not going to touch with a barge pole.  But nothing for my router - unless I'm missing something.
Avatar for Scubaian1
This message was authored by: Scubaian1 Answer
Re: Router settings in my sky app - how long to appear?
I ended up calling sky, they suggested scanning the QR code on the inside of the box lid and follow that process but they also raised a ticket to fix it.  The QR code thing didn't work but I got a text that it was fixed yesterday and all good now.  I wonder if the problem is a missing step on the original install, but it's fixed now.
Yes
Also yes, as witnessed by multiple posts in this forum.
