Discussion topic: Router keeps shoeing orange light and i have to reset it
This message was authored by: Jezza36B
I am on full fibre broadband, so have a white box on the inside wall. There is never an issue with the green lights showing on this box, but once or twice a day the WiFi goes off and the router shows an orange light. I have had the router replaced once but still happening. Is there a more reliable router available, or I will need to change to a new provider, as I work from home. Thanks.
Re: Router keeps shoeing orange light and i have to reset it
@Jezza36B  Is this the internet light that is doing amber and you lose internet access or is this the voice light going amber?
Avatar for Jezza36B
It's usually just the voice that goes amber and we can't get any WiFi. Sometimes the Internet goes orange too.
@Jezza36B  rather than doing a powercycle on the router. You can go into router management if you follow the directions in the link below until you get to show statisics there is another button beside it and you can do a disconnect and reconnect from there if you have a hardwired device.
Avatar for Jezza36B
Update - spoke to the technical dept in Sky and they advised me to move the cable from port 2 to port4 on the back of the router. I've done this and no more issues so far...
