Discussion topic: Rooter reboots randomly. Had router replaced and network cable replaced but issue still occurs.
Message posted on 20 Mar 2025 09:30 PM
Message posted on 21 Mar 2025 08:07 AM
Re: Rooter reboots randomly. Had router replaced and network cable replaced but issue still occurs.
@JohnF66 it is very unlikely to be a second dodgy hub so check for issues in your home which can be causing the issue in particular the mains supply as an unstable voltage can cause reboots. Also che that the hub is not close too or worse under of equipment.
Message posted on 21 Mar 2025 08:10 AM - last edited: 21 Mar 2025 08:11 AM
When you swapped the router, did you also swap the PSU? If you did, try plugging it into another socket for a while.
