Discussion topic: Ring doorbell and blink camera not working
Message posted on 10 Apr 2025 10:29 PM
Message posted on 11 Apr 2025 07:20 AM
Re: Ring doorbell and blink camera not working
@James1219 if other devices are connecting the most likely issue is poor wifi especially if the units are outside your home. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi. Note Sky do not guarantee any coverage outside your home.
