Discussion topic: Reset hub and healthy status on MySky but no internet
Message posted on 15 Jun 2025 09:12 AM
Sky status checker says everything is working. There is a white light on the hub but I have no internet connection using the sky wifi or the wired connection. I have reset the hub several times and restarted several connected devices
Message posted on 15 Jun 2025 09:56 AM
Re: Reset hub and healthy status on MySky but no internet
The checker looks for issues in your area so try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
