Discussion topic: Replacement of White HUB and Wifi password
This message was authored by: Madhatter
Ive just swapped over my white hub, and its got the exact same SSID and password as the one it replaced. I changed the password via the app, would the hub automatically update the wifi details?
Re: Replacement of White HUB and Wifi password
@Madhatter
I believe your SSID & password is stored in the cloud so when you replace the hub it sees your Sky ID and pulls those settings in
I am NOT a Sky Employee
