Discussion topic: Repeatedly can't access Apps on TV - no satellite signal
Message posted on 04 Mar 2025 04:53 PM
When looking at an App on TV in our living room, we repeatly get a message on the screen there is no satellite connection and I have to reboot the tv to restore it. This has only happened since you installed a new hub near my computer in another room.
The booster in one of our bedrooms used to show 3 lights but this is now 1 bright light and 1 dim light. If you think this is a WiFi booster problem, please can you provide or install a free WiFi booster which is compatible with the new Broadband hub. I would prefer an engineer to call and do this as my technology skills are fairly limited!
Thanks.
Alan Coysh
Message posted on 04 Mar 2025 05:16 PM
Re: Repeatedly can't access Apps on TV - no satellite signal
@AC1 A No Satellite Connection sounds like your TV is trying to access the inbuilt satellite tuner and is unrelated to broadband.
Have you tried checkimg your TVs user manual?
