Discussion topic: Remote WiFi connection to my laptop
This message was authored by: Graham-
My laptop and my hub won't connect wirelessly. It did when I was with BT but since switching to Sky, the connection will only work via the ethernet cable. BT Open Reach installed the optic fibre to home. Any ideas
This message was authored by: Addie15
Re: Remote WiFi connection to my laptop
This message was authored by: Mr+Flibbles+86
We are still looking to help you. If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Avatar for Graham-
Level 0 icon
Thnak you but if it of any help to others, I uninstalled the printer driver and then re-installed it. That worked
