Discussion topic: Relocating my incoming broadband box
This message was authored by: Tara1000
Hi, we need to move our sky optimal cable box to another wall but the green plug is too big to go back through the existing hole. I can see a little nut inside the plug - is it simply a case of undoing it then popping it back when the new hole has been made? Sorry if this is a silly question I just don't want to start it and then have no Internet as I work from home
Re: Relocating my incoming broadband box
No, that's a factory terminated optical connection and is extremely unlikely to survive disassembly.
@Tara1000 the fibre connection is very delicate and easily damaged. Moving the ONT is a job for a trained  engineer with the right kit so call Sky to get a price.
Avatar for Tara1000
Ah, thank you so much for confirming
