Discussion topic: Regular dropout of wifi connection
This message was authored by: Gary230
A new router I think as ours keeps dropping off wifi
Re: Regular dropout of wifi connection
@Gary230which router do you have just now from Sky looking at the link below
If the internet is dropping can you follow the directions below,
Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
