Discussion topic: Red light on sky max wifi hub
This message was authored by: StewShep
Woke up this morning and found a red light on my sky max wifi hub and no connection to the internet. I've tried unplugging and resetting the hub several times over the last hour but the red light is still here. Please help! I work from home and I'm heavily reliant on internet to work
Re: Red light on sky max wifi hub
@StewShep using a mobile conection log into the My Sky app and run the service checker as thst will tell you if Sky are aware of an issue affecting your line dont worry if it says everything is OK as it takes a few hours to pick up line drops. If it doesnt tell you there is a known fault call Sky to report it.
You are buying a domestic connection from Sky and the fact you use that for work doesnt give you any priority. The standard SLA for faults on domestic lines is a fix within 2 full business days after report which Openreach manage in 80% of cases after which compensation is paid Customer Auto-Compensation | Sky Help | Sky.com
Avatar for StewShep
Thanks for the frosty reply chrisee. Very helpful
This message was authored by: DS2DOGS
Have a new hub with red light.
Checker says I have a problem but no way of fixing it.
would be nice to speak to someone?
This message was authored by: Manning1
Did you fix this issue i have the red light issue on my sky max hub no wifi for a week and having issues with sky fixing it
This message was authored by: Donaldduck221
No new white modem box red light not going out
@Donaldduck221
This link explains the lights on the various hubs
