Discussion topic: Red light on in middle of sky box
This message was authored by: Cm2345
Broadband not working
Re: Red light on in middle of sky box
@Cm2345
If you are having broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
