		Discussion topic: Red light on alarm on openreach box
	This message was authored by: Stevie64
		Message posted on 11 Apr 2024 12:00 PM
Red light is still on the alarm section on the Openreach box and seems impossible le to report this fault to Sky.
Find out more
		Message posted on 11 Apr 2024 12:04 PM
							Re: Red light on alarm on openreach box
If the line test in the My Sky app isnt allowing you to report it then you can use the 03 number at the bottom of https://sky.com/help under 'Need more help?' Or we can escalate your post to Sky on the forum so you can chat with a rep.
I am NOT a Sky Employee
		Message posted on 11 Apr 2024 12:51 PM
Thanks for your reply but I have given up, I am just going to switch to another supplier.
