23 Apr 2024 11:17 AM
23 Apr 2024 11:44 AM
Posted by a Superuser, not a Sky employee. Find out moreHi @Herbert9
It is strange that you still have an internet connection while the alarm light is lit. Usually this would suggest the connection has degraded to a point that no access would be possible.
The best thing to do is to report it to Sky, this can be done over the phone or we can escalate your post on the forum to chat with a Sky rep.
23 Apr 2024 11:48 AM
Still not 100% sure what the alarm light represents
Conflicting reports saying its loss of service or battery backup unit .
Does your ont have a seperate box to the ont as part of the initial install?
23 Apr 2024 11:59 AM
23 Apr 2024 12:01 PM
23 Apr 2024 12:04 PM
Posted by a Superuser, not a Sky employee. Find out moreI have escalated your post to Sky, look out for a message on the forum.
It may be that @cookiemonsteruk is right and that it is a battery backup which has died.
23 Apr 2024 12:07 PM
We need to check if you have a battery back up which serves no purpoise. Could you open up the ont case and post a photo of what you see
23 Apr 2024 12:10 PM
Posted by a Sky employeeThanks for escalating this. We’ve sent @Herbert9 an invite to chat.
23 Apr 2024 12:22 PM
Ah . Possibly failed software update
Red = New ONU software not operational due to any of the following reasons:
* Software image download failed.
* Software image flash write failed.
* Software image activation failed.
* Software image commit failed
26 Jul 2024 06:43 PM
I'm having a similar issue - the wifi is showing all green - but the box on the wall has a red alarm light - and I can't get the internet to work on any devices. Any ideas what the issue is? Done a line check on the app and it says it's all good...?
26 Jul 2024 07:46 PM
Posted by a Superuser, not a Sky employee. Find out more@Forgottonspirit Is the service checker still showing that everything is okay?
26 Jul 2024 07:49 PM
I ran a check on the app and it shows as everything working fine but can't seem to access the Internet or connect to the hub
26 Jul 2024 07:50 PM
Posted by a Superuser, not a Sky employee. Find out more@Forgottonspirit In the checker did you then click on broadband to run a test to see if it finds any faults?
26 Jul 2024 07:54 PM
Yes I ran it a few times and it said it was fine 😞 but it's not
26 Jul 2024 08:18 PM
Posted by a Superuser, not a Sky employee. Find out more@Forgottonspirit I have escalated your post to Sky who may be in touch with you regarding this via a private message on this forum or an email to you, both of which will invite you to a private chat. This will happen in the morning now.
More information about this process can be found in the link below.
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
