Discussion topic: Red Voice Light then no connection
This message was authored by: WRC0
Really frustrated - upgraded to full fibre a few weeks back from fibre to the cabinet and have had nothing but trouble since.
the voice light on the hub goes red/amber pretty much every week since upgrading and then I have no internet session on my devices, a reset on the hub resolves this temporarily but it keeps happening.
what can be done?
Re: Red Voice Light then no connection
@WRC0 you need to report the issue to Sky but you maybe able to stop it happening by powering down your hub for an hour. The cause is probably a faulty server managing your connection at the exchange.  Powering down should get you connected to a different port which is working properly. Sky will get round to fuxing the unit but it takes time to happen.
This message was authored by: kac55
Exactly the same situation as described. Will give the suggested answer a try. It's annoying because it is always like this when we wake up in a morning, and there is much more to do than unplugging connections. Thankfully just oince a week.
This message was authored by: Mattyp1239
Really annoyed just switched from zoom less than a month and the red light voice is on , first day kids off school and engineer can't come out
