Discussion topic: Received an email claiming I applied for Sky Wi-Fi although I didn’t ..
This message was authored by Nomsi This message was authored by: Nomsi
Re: Received an email claiming I applied for Sky Wi-Fi although I didn’t ..
@Nomsi
Do you have sky broadband?
The only way you should get any communication like that is if you are using The Cloud wifi hotspots in bars etc etc
Do you have the email of the sender
