Discussion topic: Re: Want to speak to a sky advisor
This message was authored by: Mumx5
Can't change my wifi password on the hub and need to speak to an advisor
@Mumx5 Sky's agents cannot change passwords remotely so try using these instructions https://www.sky.com/help/articles/find-and-change-your-wireless-password
they definitely work if they dont check you are entering the current password corrrectly its easy to read the number 0 for a letter O etc.
If you want to call Sky using your Sky Talk line and dial 150 for a free call.
Avatar for Mumx5
Thanks I've found where to do it...is the username and password the same as my log in do you know by any chance. I can't log  into the change wifi change password.
@Mumx5 read the pages linked in my post the Hub's username is normally admin but it is all explained for each model of hub as they differ.
