25 Oct 2022 08:01 PM
Hi All, 2 questions please:
1. WiFi Handsets - do BT WiFi handsets work on Sky Hub Wifi?
and
2. Will a wireless standard phone base unit with 5 wireless handsets (eg Panasonic) work if the base unit is plugged into the UK phone socket of the Fibre to House Sky Hub with Superfast Broadband and Talk?
Thankyou
25 Oct 2022 08:20 PM
No, those are specific to BT Broadband with one of their Smart Hub 2 routers.
25 Oct 2022 08:04 PM
Dect phones with standard bt jack where the base station is plugged into the sky hub and the others scattered around the house will work
25 Oct 2022 08:06 PM
Thankyou - do you know the WiFi handset answer as well please?
25 Oct 2022 08:07 PM
Sorry to ask but...If Phones and bas unit are not DECT - will it work then?
25 Oct 2022 08:12 PM
They do use around the same frequecy as the 2.4ghz wifi but it is solely for communication between the handsets so its effectively not the wifi as we would know . Ie they don't connect to the sky hub
@GD1 i believe you have panasonic dect phones. Do they operate around 2.4ghz
25 Oct 2022 08:13 PM
What model panasonic. Does the base have a standard bt phone?
25 Oct 2022 08:19 PM
Is the cable like this
Posted by a Superuser, not a Sky employee. Find out more@cookiemonsteruk Like all UK Dect phones they should be operating on 1.88 to 1.9ghz
25 Oct 2022 08:22 PM
@cookiemonsteruk @GD1 @TimmyBGood
Thanks for your helps guys...I have a Panasonic KX-TG8424EM Base Station....no idea re the GHz unfortunately...can you shed any light if its DECT?
Trying to determine if they actually dect . Otherwise how would the other phonesets work 🤔
@cookiemonsteruk Cable is like the bigger of the 2 - std BT Phone plug
25 Oct 2022 08:24 PM
@TimmyBGood --thanks for the answer - appreciated
25 Oct 2022 08:34 PM
As I understand it, wireless walkabout phones with base stations may be DECT if they are the premium ones but the cheaper ones are not DECT.....I believe that DECT is a more refined specification.
25 Oct 2022 08:44 PM
@cookiemonsteruk Trying to determine if they actually dect . Otherwise how would the other phonesets work
The
My Panasonic Phones are to the DECT and GAP standards according to the Ops Manual
