Discussion topic: Re: Alternative to Sky Broadband with Sky TV
Message posted on 04 Mar 2025 10:46 AM
Im with sky and my Internet cuts out at between 1.30 and 2.30 every night pain in the rear end if I'm working on my laptop and then got to wait for it to reconnect
Message posted on 04 Mar 2025 11:58 AM
It could be overnight maintenance taking place.
If it still down later then the first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Message posted on 04 Mar 2025 03:47 PM
It's not the internet, it's the Q doing its overnight cycle. Your laptop is probably connected to its mesh.
Message posted on 06 Mar 2025 12:25 AM
This been happening every night since fibre installed which was back in August time last year thought it was something like that to start with but it's continued every night
Message posted on 07 Mar 2025 07:21 AM
Yeah, the Q box cycles itself every night
Try turning off the "use sky boxes to extend your network" option - I think it's in the installer menu.
Message posted on 07 Mar 2025 07:56 AM
It's not the sky q box I don't even gave the sky q box on I'm normally on laptop it the actual Internet checked the Internet and all lights are off have to wait for it to all reload again
Message posted on 07 Mar 2025 08:07 AM
@john771092 simething is wrong to lose internet connectivity every night for months as maintenance only happens occasionally for maybe a week or so at most. It does not sound like Q boxes turning off their wifi hotspots in eco standby as thst is timed for 2.30 am to 5.45am. I assume you have excluded timers erc in your property so I would call Sky but it is difficult to know what it could be. One possibility is if your's is a partial fibre connection is the cabinet resetting but thst only takes a minute or so and shouldn't happen every night. Full fibre is not affected by that.
Message posted on 07 Mar 2025 11:22 AM
All lights are off? Ok that is very odd.
(you don't have to have the Q box on to be using its mesh but given the above, this seems likely to be weird behaviour by the router.
