19 Feb 2023 01:08 PM
Got a new booster from Sky yesterday to replace my faulty one I had . I used to connect an Ethernet cable from my tv to the old booster but noticed there is not a connection on back of the new booster for this anymore . Anyone got any ideas why this is so? Tried on sky twitter feed twice but got no reply? Thanks
19 Feb 2023 01:15 PM
Quite possibly because whoever is manufacturing them for Sky has had problems sourcing an appropriate chipset due to the ongoing global silicon component shortage.
19 Feb 2023 01:27 PM
Or possibly they don't want a third party box, like say, Amazon cube connecting to it?
19 Feb 2023 01:58 PM
Posted by a Superuser, not a Sky employee. Find out moreI doubt that was a factor. Sky might be prepared to swap the booster for a different unit, but it's entirely possible their logistics system cannot differentiate between the different models.
19 Feb 2023 02:50 PM
Strange no Ethernet connection on this one. Never heard that before...
19 Feb 2023 03:06 PM - last edited: 19 Feb 2023 04:07 PM
Posted by a Superuser, not a Sky employee. Find out moreIt's a more recently manufactured batch of the existing model: hence the minor variation in model number.
19 Feb 2023 03:14 PM
Yes and a minor variation of no Ethernet connection as well
19 Feb 2023 03:51 PM
Posted by a Superuser, not a Sky employee. Find out moreI'd imagine Sky had the choice of no ethernet port or no boosters. Most users will never connect a booster using a network cable anyway, but it's a pain for the small number who wish to do so
19 Feb 2023 04:12 PM
I used mine connected via Ethernet cable to my smart tv or Amazon fire cube. Gave a better and more stable Wi-Fi connection at the time
19 Feb 2023 04:19 PM - last edited: 19 Feb 2023 04:20 PM
Posted by a Superuser, not a Sky employee. Find out moreLike I said, Sky might be prepared to swap the booster they sent for a different one, but it would be more by luck if you received a replacement with an ethernet port: presumably all the new units are the same, while you'd want a refurbished one from a previous batch.
21 Feb 2023 10:46 AM
This is certainly not the reason, it is in Sky's interest to let you connect devices via ethernet because it reduces the amount of support calls they'd get for WiFi related problems.
Its down to chip & manufacturing shortages.
21 Feb 2023 10:48 AM
I was ble to connect the fire cube from Amazon easily and connection is stable again so no real need for Ethernet . Seems better to be truthful/
