Discussion topic: Q Box and Booster not connecting to hub
Message posted on 26 Sep 2024 09:13 AM
I had to re-set my hub last night and since this neither my Q box or my Wifi booster will connect to the hub. I've tried re-setting, turning on and off and pairing via the WPS button but nothing works
Message posted on 26 Sep 2024 09:30 AM
Re: Q Box and Booster not connecting to hub
@tomcranmerWhich hub do you have from Sky from the link below.
https://www.sky.com/help/articles/sky-wifi-booster-setup-what-booster-do-you-have
Message posted on 26 Sep 2024 09:33 AM
It's the sky broadband booster.
Message posted on 26 Sep 2024 09:34 AM
@tomcranmer You have the router that goes with this booster also or have you changed routers?
Message posted on 26 Sep 2024 09:35 AM
No I haven't changed my router. As far as I'm aware I have the one which links to this booster. It was set up by a sky engineer
Message posted on 26 Sep 2024 09:38 AM
@tomcranmer Are any devices connecting to the Wi-Fi on that router or is it just the Q box and the booster that are having the issues? Do devices connect via ethernet if you have any and what colour are the lights on the router just now?
Message posted on 26 Sep 2024 09:42 AM
Yes my phone connects to the Wifi no problem.
Router lights are all green.
Sorry I'm not at home to test the ethernet connection
Message posted on 26 Sep 2024 09:47 AM
@tomcranmer As long as something connects to the router via Wi-Fi. Have you tried to manually connect the Q box using the Wi-Fi password rather than the WPS button?
Message posted on 26 Sep 2024 10:00 AM
No I haven't tried that, will give that a go when I get home. How will I connect the booster though?
Message posted on 26 Sep 2024 10:07 AM
@tomcranmermight be that the booster is dead. But if you are unable to connect the Q box then there could be bigger issues at hand.
Message posted on 26 Sep 2024 10:15 AM
Everything was working fine until I had to re-set my hub last night
Message posted on 26 Sep 2024 10:59 AM
@tomcranmer Why was the hub re-set needed in the first place?
Message posted on 26 Sep 2024 11:00 AM
Internet connection dropped out completely. Took a few hours for it to come back
Message posted on 26 Sep 2024 11:04 AM
@tomcranmer Did you try and reset the booster also after it would not connect?
Yep done that and the tried to link via WPS but no joy
