3
This discussion topic has been answered Discussion topic: Proposed Transfer from BT Gigabit + Digital Phone to Sky Gigabit + Digital Phone
This message was authored by: Caravanj
When we moved into our new-build house in 2014 we went with Plusnet but when FTTP became available Plusnet didn't offer VOIP so we transferred to BT & subscribed to their gigabit broadband & VOIP package & although we have had no problems the cost is £85 & a colleague recommended Sky so I'm thinking of getting a Sky gigabit broadband & Sky Talk unlimited package which will save me around £27 pm.
However,  my colleague had the Alexa issues that have been well documented in other posts  when he got his new Sky gigabit router & eventually I advised him to return it & continue to use he existing black router which he has done.
My situation is that I have 14 Blink CCTV cameras,  4 Tapo CCTV cameras & numerous   Echo Dots, Echo Flexes & a couple of  Echo Shows  plus around 50 smart plugs. Ethernet sockets & landline sockets were installed in most rooms when the house was being built & a mesh sytem handles all the WiFi devices. I plugged the BT router landline socket into the BT master socket ( so I could still use the sockets) that Openreach left in situ & plugged a digital base station into the hall landline socket which enables all our digital phones to work & a couple of analogue phones plugged into the room sockets.
Obviously I don't want to have issues with all of this setup but I'm assuming that if ( as I did from Plusnet to BT) I change the Sky router SSID name to the Plusnet SSID name & the Sky router password to the Plusnet router password everything should work from the switch on.
The Tenda WiFi mesh system is  tri-band with one 2.4GHz channel & two 5 GHz channels & the WiFi on the BT router is disabled.
Can anyone see where my assumption may not work if I do swap to Sky?
Thanks you for any advice or suggestions.
This message was authored by: JimM1 Answer
Re: Proposed Transfer from BT Gigabit + Digital Phone to Sky Gigabit + Digital Phone
@Caravanj You should be fine doing as you are wise move so far, just allow the Landline 24-48hrs to all gel together, treat incoming/outgoing/ and all different services as seperate items during the period! No more than that time wise, any issues get onto sky pronto to sort out the Voice side!
Avatar for Caravanj
Level 2 icon
Well I've made the decision & today I've signed up to a Sky subscription for 900 Mpbs with unlimited SkY Talk for £55 pm which is £28:40pm less than I'm paying BT.
I did study the manual for the Sky Max Hub & it can be set to WAP2 which is compatible with Alexa & I can turn off the WiFi function & let it all be handled via my mesh system so in theory all should be good.
I don't use a BT digital phone for my BT digital calls so again all should be good.
I will be honest & post if I do have smart device issues after I change to Sky.
Avatar for Caravanj
Level 2 icon
Or WPA2 even. Lol
