Discussion topic: Problems with Sky Q hub
This message was authored by Rssll This message was authored by: Rssll
I used to be able to log in to my desktop computer from my laptop. Recently it stopped working and I would get, Server Not Available.
I tried to log in to the hub but it wouldn't accept my password. I did a reset and was able to log in with the original password. But when I try to apply any changes I get, the server unexpectedly dropped the connection.
Is there anything I can do or do I need to contact Sky?
Re: Problems with Sky Q hub
Typically accessing the Hub admin pages over WiFi, particularly using Safari browser from an iThing, can be problematic.
Rssll
I have also tried it on the desktop with ethernet connection.
@Rssll
Make sure you are using a browser that has no form of ad block/tracker enabled as it can mess with the hubs settings.
If it still doesnt work you'll need to try factory resetting the hub, you can do this by holding the reset button on the rear of the hub for 30 seconds.
I am NOT a Sky Employee
