2
Discussion topic: Problems accessing router settings
This message was authored by ajimagemaker This message was authored by: ajimagemaker
Hi. I'm trying to acess my router settings. However my username and password aren't allowing access?
How can I get into my settings?
Adam
This message was authored by jamesn123 This message was authored by: jamesn123 Answer
Re: Problems accessing router settings
@ajimagemaker
If you have the Sky Q hub then the username is admin and password is sky
If you have the Sky broadband hub then the username is admin and password is your default WiFi password
I am NOT a Sky Employee
@ajimagemaker
ajimagemaker
all sorted!
thanks for that!!
