Discussion topic: Problem connecting Apple mobile to Sky Braodband
This message was authored by: Stonewall1
Just changed from BT to Sky Broadband, but Apple mobile will not connect and keeps saying wrong password even though it is the password on the router?
Re: Problem connecting Apple mobile to Sky Braodband
@Stonewall1
If you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as show on the hub itself so use upper case letting if required.
