Discussion topic: Printer needs frequency change
This message was authored by Wallace10 This message was authored by: Wallace10
Hi All, hoping someone can help, i have a HP printer, after speaking with HP technical support they have advised that i need Sky to make the below changes, i cannot get hold of anyone at sky to talk to to help me so im hoping someone on here may be able to give me some advice.
Many thanks
Nick
"I would kindly ask you to please contact your Internet Provider so they can separate frequencies to 2.4 GHz and 5 GHz, and open the necessary ports for you. Those ports are TCP and UDP Ports: 45222 & 45223, 80, 5353, 5358, 5222, 5223, 5357, 3702, 443, 427, 8080, 209, 1900, 5298, 5350, 5351."
Re: Printer needs frequency change
@Wallace10  You don;t need to call Sky to split the wifi bands if it's dual band router, this is best done with an ethernet conneceted device.
  • Type 192.168. 0.1 into your browser.
  • Select the WiFi tab.
  • Enter the login details that apply to your Sky Hub. ...
  • Scroll down and untick the 'Synchronise 2.4 GHz and 5 GHz Settings' box.
  • To help identify the two WiFi bands, edit one of the SSID's to make it identifiable. ...
  • Select Apply.
