Discussion topic: Printer connection issue.
This message was authored by Gizmo130 This message was authored by: Gizmo130
I am trying to connect my printer useing the wire as its not WiFi and I can not get it to connect. I have checked all the leads turned everything off and started again. I have been trying for 4 hrs.i have follow guides previously on here and on internet and nothing has worked. Anyone have any ideas. It's a office printer a konica bizhub.
This message was authored by mae-3 This message was authored by: mae-3
Re: Printer connection issue.
@Gizmo130
It would be helpful to have the model number of the printer. But generally speaking, it should be a matter of connecting the printer to the Sky Hub router by ethernet cable or wifi whichever is easy for the position of the printer in the house.
Gizmo130
It is a konica minotaur bizhub C224e.
I have plugged it in and it just says no network. I jave spent 4 hrs trying to get it to connect. When I do the troubleshoot it says no network. The only thing that has changed is me changing over to sky from bt.
This message was authored by cuke This message was authored by: cuke
I suggest you reset the printer too it's factory default, comnect it to the router then check if it's in the list of devices and if it is take a note of the IP address. Then see if you can ping it from your laptop or desktop.
