Discussion topic: Power the sky max hub over poe
Message posted on 13 Jun 2025 04:53 PM
Would it be possible to power the sky max hub over Poe using a Poe splitter connected from a Poe switch?
Message posted on 13 Jun 2025 05:34 PM
Re: Power the sky max hub over poe
@Jonathan1983 No, hub does not work in that method.
Message posted on 14 Jun 2025 11:57 AM - last edited: 14 Jun 2025 12:00 PM
PoE requires the ethernet port(s) on the client device to support inbound power: that's an extra manufacturing cost which ISPs are unwilling to incur given the overwhelming majority of subscribers won't use it.
It's not entirely impossible to extract PoE from the RJ45 plug and reintroduce it on a dedicated power jack, but this wouldn't be advisable on loaned hardware.
