Discussion topic: Poor wifi signal to rear of property
This message was authored by: Daniel281076
Message posted on 20 Nov 2024 07:59 AM
Hi we are experiencing poor and slow wifi to the rear of our property
Find out more
Message posted on 20 Nov 2024 08:06 AM
Re: Poor wifi signal to rear of property
@Daniel281076 incredibly common issue as in many homes you need multiple wifi sources to get usable WiFi in every room. Wifi signals lose strength passing through walls etc the denser the wall the more strength thst is lost. Make sure you hub is not losing signal unecessary so endure it is out in the open on a surface above obstructions like radiators.
Sky will sell you their WiFi Max bundle which can supply up to 3 pod extenders if required see https://www.sky.com/help/articles/sky-wifi-max or you can buy your own equipment if you prefer.
