This discussion topic has been answered Discussion topic: Poor speed to hub and dropouts
Message posted on 06 May 2024 08:38 AM
Hi all
We have had the new sky max hub for a few weeks now but the speed to the hub is constantly all over the place. We are on ultra fast. Some days the service checker will show 148mb and then drop to 80/90mb for a day or two then it jumps back up so its never below the 100mb guarentee for three days straight.
The second issue is the wifi drops out most days for a minute or so the recconects. This happens on multiple devices. We live over 3 floors and probably need a booster to help reach the top floor stream box.
Message posted on 24 Sep 2024 09:30 AM
An update on this. Despite being helpful and trying quite a few things Sky have been unable to fix this issue. There is no line fault. We have a new max router which made no difference. Disconnected various devices and no difference. Sky have exhausted all options over the course of a week and the speeds have still fluctuated between under the speed guarentee and just over with the occassional day where it was what we were paying for. They have basically said its either put up with it or I am free to leave. I cant help thinking the new max hub is the likely cause especially after seeing so many comments with similar issues. They did suggedt a profile reset might work but i would need to upgrade speed for this to take place and no guaretee. So If they cant fix it I will need to go elsewhere.
Message posted on 07 May 2024 08:10 AM
Re: Poor speed to hub and dropouts
This morning we have had the Sky service app tell us that we have dipped below the minimum for 3 days. Wifi is still terrible in some parts of the house and we are getting roughly half the speed we are paying for. We never had this issue before moving to the new sky router
Message posted on 07 May 2024 08:12 AM
Can you post your hub stats
Message posted on 07 May 2024 08:16 AM
How do I do that on the new sky max hub.
Message posted on 07 May 2024 08:18 AM
Good question. @Chrisee any ideas
Message posted on 09 May 2024 09:31 AM
Sky have acknolegded that the speed to the hub is poor and have refunded for it. However the service checker is still saying poor speed to the hub and now poor wifi signal from the hub. I have no way of posting stats as on new max hub. Im pretty sure the next step will be a booster but waiting to get through to sky is ridiculous and web help keeps sending me here.
Message posted on 10 Sep 2024 08:45 AM
I am still having issues with this and i cannot get in contact with sky they keep sending me here. We are using the white max hub and coverage is sketchy over 3 floors so probably need a booster pod. We are getting dropouts and the speed is quite often well below what we are paying for. Any help is appreciated.
Message posted on 10 Sep 2024 12:16 PM
If you have the Sky WiFi Max addon you should be entitled to pods. I've escalated your post to Sky, look out for a message on the forum
Message posted on 10 Sep 2024 12:35 PM
Thanks for escalating this. We’ve sent an invite to @Glover85 to chat.
