2
This discussion topic has been answered Discussion topic: Poor signal upstairs in home
This message was authored by: helen2306
Hi I feel we need a signal booster in our home as the signal is poor in some areas upstairs in house
Re: Poor signal upstairs in home
@helen2306 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
This message was authored by: Diehard_si
As someone whos just registed and having similar and other issues, this is poor from Sky.
The old routers worked ok. The new routers are awful regarding WIFI signal, but they want to charge you £8 per month to fix a problem they have themselves created.
This is how you lose loyal customers as a business.
