Discussion topic: Poor signal to room with console in
This message was authored by: Beccy24
Just got superfast fiberoptic WiFi and it's still very poor in my sons room where he plays the xbox which is stressing him out.
Re: Poor signal to room with console in
@Beccy24
Its never a good idea to game over WiFi, ideally you should use ethernet to connect your sons console. Powerline can often be a good option to achieve this.
I am NOT a Sky Employee
Avatar for Beccy24
The bedroom with the console is to far from.the room with the modem in to connect with a cable.
@Beccy24
Hence why I suggested powerline as a different option. The link below explains how they work
https://www.tp-link.com/us/powerline/
Avatar for Beccy24
Thank you for your advise.
