Discussion topic: Poor signal to cameras.
This message was authored by: Jbad
I have Sky Q  and have had Sky fast fibre broadband installed, I also have 2 external cameras which rely on a wi-fi signal.
After the fibre boadband was installed I had a reasonable signal to the cameras, now that I have added a Sky Q booster to the setup the signal to the cameras is poor, is there any thing I can do to restore a reasonable signal again.
Re: Poor signal to cameras.
@Jbad
Adding a booster should not cause worse signal in a certain area. What was the booster added for? Is it required?
I am NOT a Sky Employee
Avatar for Jbad
The booster was added to get abetter signal on the top floor of the house.
@Jbad
I can only suggest moving the booster around a bit to see if the signal for the cameras changes.
