Discussion topic: Poor signal around the home
Message posted on 24 Jun 2025 04:19 PM
Signal poor and drops out since upgrading to speed 300
Message posted on 24 Jun 2025 06:24 PM
Re: Poor signal around the home
@Wazlippitt Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Message posted on 24 Jun 2025 06:29 PM
@Wazlippitt What did you upgrade from to your new package, and anything else that was down at the same time!
