Discussion topic: Poor connection on fibre
This message was authored by: David12345r
Since I upgraded to fibre in July. The Wi-Fi signal is worse than it was on the old 25/30 mbs. Even the sky tv buffers sometimes.
Seems like it takes a while to get connected and is intermittent signal compared to old broadband
Re: Poor connection on fibre
@David12345r what coloured hub do you have? Increasing the speed to the hub wont always increae wifi speeds in your home as the limiting factor is wifi signal strength which is affected by the layout and the type of construction of your home. If Sky have sent you a white hub and you had Sky Q boxes tgese no longer work  to extend wifi coverage. Another possible factor is the location of the hub somecfull fibre installs are in a bad position somthe hub's wifi is lower as a result.
