Discussion topic: Poor connection in one room for tv and wifi
Message posted on 15 May 2025 04:39 PM
We have a max pod booster in our kitchen which helps iPad and phones however the room after that regularly cannot support eg BBC player and constantly try's to load, this only happens in this particular room (we are a bungalow). Do we need another booster to remedy this?
Checking the download speed it can be 40 in the main part of the house and only 9 in the room in question
Message posted on 15 May 2025 04:49 PM
Re: Poor connection in one room for tv and wifi
@Hilda24 You can try and see if sky will oblige, but you do not want to be daisy chaining booster's NOT the way to go, would look at powerline but that will be at your cost and also may provide a better solution. Call sky and see if you can get the second booster from them!
