Discussion topic: Poor connection. Download Speed 15 BUT Sky website says 148!!!
Message posted on 03 May 2025 06:54 AM
Independent speech checker reading 10-15 download speed but app says we're getting 148!
dropping out of calls and impacting work.
what's going on?!
Message posted on 03 May 2025 07:12 AM
Re: Poor connection. Download Speed 15 BUT Sky website says 148!!!
@Hmohmo how are you measuring speeds? If it is on a device connected to the Sky hub by WiFi you are probsbly measuring the speed of the WiFi connection in your home which is lergely outside Sky's control. To check the speeds to the hub reliably you need to run the test on a device connected by a Gigabit Ethernet cabled link.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
