Discussion topic: Poor WiFi signal in parts of our house
This message was authored by: TonyPro
We are new customers. Strong WiFi signal in the main part of our bungalow but no signal at the front and back of the house. Cotswold stone walls caused problems with previous BT broadband but signal boosters sorted it at the front and back of bungalow.  Can you advise?
Re: Poor WiFi signal in parts of our house
@TonyPro Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
