Discussion topic: Poor WiFi in rooms where the router isn’t.
Message posted on 20 Apr 2025 09:27 AM
Hello my WiFi seems to be excellent in the living room where the WiFi router is. However in every other room whether it is downstairs or upstairs I seem to get really poor connection. It's is usually at speed of around 300 in the Viking room but around 10/15 anywhere else.
Message posted on 20 Apr 2025 09:31 AM
Re: Poor WiFi in rooms where the router isn’t.
@LukeGrocott Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
