36
This discussion topic has been answered Discussion topic: Play store downloads stuck on random percentages. Since 15th April
This message was authored by: LACOSTE
Got a sky max hub, held the reset button for 30 seconds till green light.
Restarted hub
Restarted phone
Cleared cache on play store
Tried mobile data worked fine
Issue appears to be only using sky internet since what I reckon was a router update broke everything.
Can you guys raise this to business resilience, seems like the same bug that affected people back in January as it also breaks parts of YouTube etc
This message was authored by: KevNewMedia Answer
Re: Play store downloads stuck on random percentages. Since 15th April
Posted by a Sky employee
Hi Everyone
Can I ask you to try again and let us know how you get on, by replying to this thread, please?
Kev
Community Manager
@LACOSTE please post details of the device and version of Android as while you might be correct Sky will need those details to track the issue if you finger me I will escalate your post to the forum support team.. As far as I have seen yours is the only recent report in the forum if the issue was back we would expect to get a lot of similar posts
This message was authored by: dog3
Play store app wont download or update
Play store Apps won't download or update
Re: Play store app wont download or update
@dog3 check the setting for Broadband Shield in the My Sky app as the lower ones will block online gaming activity.
This message was authored by: Ash_75
Same issue here. My Sky broadband shield is turned off so it's not related to that. It has something to do on Sky's end as I saw in the forums that it happened in January as well.
For reference, the area is South Yorkshire and this is happening on google play store and sometimes in youtube (when it randomly starts buffering).
Hi, the same thing is happening to me.
Here is some additional info for diagnosing this issue:
Phone: Google pixel 8a
Android version: 15
Sky broadband: Now full fibre 75
Broadband shield: turned off
Region: South Yorkshire
When I use my mobile data I can download/update apps from the play store. but when I switch back to Sky wifi, it gets stuck again.
I also tried troubleshooting by clearing cache, restarting, etc. but it's not fixed.
@Ash_75 I am escalating your post to the Sky team who support the forum who should be in touch soon to offer you a private online chat session to get this sorted. Keep an eye on the forum as if you miss the message just click the brightly coloured chat icon which will be added to the forum pages for you to use.saving a long phone call.
This message was authored by: Addie15
Hi there! Thank you for escalating this. We have sent an invite to @Ash_75.
Avatar for LACOSTE
Hi, I'm on android version 15
S23 ultra
Sky broadband shield is also turned off.
Only a VPN gets YouTube or play store to work correctly, or mobile data.
YouTube fails to load some videos now, play store fails to download most apps.
[content removed]
This issue is also seemingly raised on 15th April by another user mentioning the same issue but they had a sky q hub 3.0 instead of the latest Max hub.
Moderator note: information removed
Avatar for LACOSTE
After some research I've found it could be related to ipv6 not being enabled perhaps, however when I try to access the router settings on 192.168.0.1 to change this it fails, and says DNS could not be found or something similar. So I'm unable to alter anything, tried this on multiple browsers.
However this issue started at random, before I did any resets on the hub etc
@LACOSTE Scottish area working fine, able to get to play store and download any updates.
Avatar for LACOSTE
I'm in Derbyshire, the other report I saw was south Yorkshire.
Also nothing works on my partner's iPhone either relating to YouTube too
This message was authored by: alisonmanic
I posted the same thing yesterday!! Also android.
Spoken to Sky broadband technician support and have sorted issue
While on phone to them
1. Told to input   192.168.0.1 on Google search
This takes you to your Router setup
2.click on WiFi (top left)
3 user name .   admim
Password  your router Password
4. He then told to change security options to Mixed Mode (bottom option)
5 .Apply
Hey presto ..went to play store and all my apps updated 100%
Hope this helps
If unsure call Sky who will guide you through it
Thanks! Done that will see the next time i have an app update!
